Hi! I am trying to do a simple pattern on an unrolled sheet metal cylinder...but when the flat pattern re-rolls, the cut/extrudes do not show up. This is a simple use case at this point, so hopefully I am missing something?
(images attached, as well as fusion file)
Nick Kloski
Solved by jhackney1972. Go to Solution.
Sounds like you are making your features on a Flat Pattern. You should be using an Unfold command, place your features and then use the Refold command.
Edit: Your file is attached with a feature
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Something was niggling in the back of my head about the Unfold command...that's it, thanks!
Nick Kloski
