Flat pattern will not show features when rolled
2 REPLIES 2
nkloski
350 Views, 2 Replies
Hi!  I am trying to do a simple pattern on an unrolled sheet metal cylinder...but when the flat pattern re-rolls, the cut/extrudes do not show up.  This is a simple use case at this point, so hopefully I am missing something?
(images attached, as well as fusion file)
Nick Kloski
2 REPLIES 2
jhackney1972
in reply to: nkloski
Sounds like you are making your features on a Flat Pattern.  You should be using an Unfold command, place your features and then use the Refold command.
Edit: Your file is attached with a feature
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
nkloski
in reply to: jhackney1972
Something was niggling in the back of my head about the Unfold command...that's it, thanks!
Nick Kloski
Technology Administrators
