Flat pattern doesn't unfold bends close to 180 degree.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've found that flat pattern doesn't work if there are slight bends that are close to flat. Within 1 degree or so of 180, it will create a flat pattern but it won't actually flatten those bends. Looks like Fusion just doesn't recognize it as a sheet metal bend at all for some reason if it is less than 1 degree. I can get it to work by manually putting a fillet in the sketch used to extrude the sheet metal flange, but that creates its own set of problems. Changing sheet metal rules and bend parameters doesn't seem to have any effect. Nor does trying to go from side 1 to side 2 when creating the part. This is getting really frustrating as the model I'm working on has tons of slight bends like this, with no easy way to just force them to bend further so I can unfold them.
Is this a bug, or is there a rule or parameter or something that I'm missing?
