Fusion 360 Simulation - Thermal. Electronics passive cooling in sealed enclosure
Is Fusion 360 capable of thermal simulation for sealed electronics enclosure?
+ There is one heat source, known wattage
+ Heat source placed into sealed case
+ Case walls has known material
+ Outside-of-case environment temp to solve for is known.
For full analysis one should need convection, conduction, radiation and conjugate heat transfer (buoyancy).
It could be simplified by using only convection and conduction (although radiation in natural convection gives quite a lot) giving sim model having 3 thermal resistances
<-> T(source)
<-> R_convection(air inside enclosure)
<-> T(enclosure inner wall)
<-> R_conduction(enclosure wall)
<-> T(enclosure outer wall)
<-> R_convection(ambient air)
<-> T(ambient)
I took a look at "PCB Design Thermal Analysis" video which is on Autodesk official channel https://www.youtube.com/watch?v=Xe3Fo4_hrUM
At 31:30 actual end product is shown with case, but the video never solves for it. 40:35 the presenter sets up the convection as if PCB board is placed directly in atmosphere (infinite thermal mass) having 25C. Well, maybe that was just a simplification as the presenter assumes that the case in video has so many holes that for practical purposes sim can be set up in the way it was done. Or maybe it was just done that way because Fusion is incapable of simulating the setup with enclosure?
I am attaching a super simple sample model that consists of 100x100mm FR4, that has 50x50 discrete component on it (source), that has dummy aluminium heatblock on it, everything enclosed in ABS case.
It has one simulation set up, where enclosure was removed in "Simplify" stage.
If the matter in question is possible, how would one set up such sim in F360?
If the matter in question is not possible, how does it correlate with what is F360 meant (as my understanding goes:)) for. I mean, take for example the sample video, it shows that F360 was used to create "everything around the electronics" (MCAD), not PCB (ECAD), IMHO it would be quite natural to assume that F360 exactly CAN solve the issue in question - validate enclosure design; otherwise F360 thermal sim is just an extension for Eagle to validate PCBs with components placed in atmosphere.
Other references: "Approach B" as discussed in this SimScale webinar. https://youtu.be/zbG9Dfy49Js?t=1978
Thanks in advance!
