That is what threw the error. Fusion keeps caches of information in the background. After you removed the original
projection there was a mis-match between what was actually there and what fusion thought should be there. The
software could not match up what was in the cache with what was there, hence the error. There is a difference
between the yellow warnings and the red errors. Fusion threw the yellow error because it didn't make a difference to
the end result and was telling you about the discrepancy. If the issue broke the model, like if that particular
projection was the only defined point in the sketch, then it would have thrown a red error instead.
Not all yellow warnings are game breakers, but there are enough that are that the forum recommends to fix them
ALL as they happen.
You may also notice that by breaking the link, you now might have a random point in the sketch that is undefined
because it is just hanging in space. If you had deleted it the point will disappear and leave the sketch defined as
normal.
Cheers
Andrew
