find an angle from given height and length
maroto77
Message 1 of 8
maroto77
(disclaimer I'm not a math person), but
I'm working in some parametric design in the sheet metal environment.
my problem: I need to calculate the angle "ang1, ang2" so that i can create a flanges that matches the angle of existing "walls".
I know that we need the inverse of tan -1()
play with this but not there!
ang1 = tan((d-c)/b)
any help would be welcome. Thanks in advance.
Replies (7)
Message 2 of 8
MRWakefield
I think you intended to attach an image but it's not there. Can you try again? Just use the "Insert Photos" button.
EDIT: Ignore that, It's there now.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 3 of 8
MRWakefield
Try this:
ang1=180-atan(b/(d-c))
ang2=atan((a-b)/d)+(180-ang1)
Marcus Wakefield
Message 4 of 8
maroto77
Hello MRWakefield,
Thanks for the Math Magic (help).
It works. It works.....
Message 5 of 8
MRWakefield
It works for me so maybe there's a bracket or something in the wrong place. If you can upload your f3d file I'll take a look. I've attached an Excel spreadsheet if it helps.
Marcus Wakefield
Message 6 of 8
maroto77
your formulas where Perfect.
I was doing it wrong. (figure out the problem and solved it)
thanks again for the help
Message 7 of 8
g-andresen
have a look
Message 8 of 8
laughingcreek
@maroto77 wrote:
..I'm working in some parametric design in the sheet metal environment.
my problem: I need to calculate the angle "ang1, ang2" so that i can create a flanges that matches the angle of existing "walls"...
There is a good chance you can skip the math and let fusion figure this for you. Can you attach your model, or a simplified model with a mock up of the problem?
