Filling an Unstitched body back to a Solid
jimmberry
jimmberry
Can you give advice on how to make this into a solid object?  I had to unstitch it so i could make the spout on the end.   I intended to do a loft but that's not working.
Patch isn't doing what i wanted either.
An export of the component is here:
Accepted solutions (3)
Replies (13)
jhackney1972
Here you go.  Use Surface Patches and Surface Extend on the inside wall and inside lip.  Then Stitch the result to get a continuous inside wall.  Use that to Trim a complete Surface Patch over the top.  Last Stitch it all together.
John Hackney, Retired
jeff_strater
I don't know your intention with the two little boxes, so I ignored them.  The screencast below shows how to get a surface on top of the model and stitch it back into a solid.  Hopefully that gives you some idea how to progress.
Jeff Strater
Engineering Director
jhackney1972
@jeff_strater that is a cool way to get the top surface!  I approached it with all surfaces, which is truly not as elegant.  I learned something tonight!
davebYYPCU
You can decide what to do with body 6 and 7.
Hide those 2, and stitch the rest together.
Loft the top edges and then stitch the all together.
Will be a solid body with 2 surface open boxes, hidden inside.
Might help...
jhackney1972
I refined my surface work a bit to get a better fill surface so the attached model is a better form at the spout.
jimmberry
Hey all,  These are some pretty amazing anwers and I wanted to let you know that i'm going over them like 10 zillion times.  A lot of this was over my head as I'm still in rookie mode.
Thanks so much!!   I'm not done looking at this.  I'm practicing techniques shown here before i try it on my real model.
jeff_strater
glad to hear it.  If any or all of these feel like a solution, please click on the "accept solution" (on the posts where the solution is posted - you can select multiple).  It helps others who are looking for similar answers find a thread that has a solution.  Thanks!
Jeff Strater
rushabhthakkar_910
Got to see some really good tips and skills....
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
ritste20
I never thought about sweeping the connecting line between the inside and outside faces. My approach would have been more in line with @jhackney1972 with extending and trimming surfaces.
Thanks for the insight @jeff_strater
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
jimmberry
@jhackney1950  and @jeff_strater  thank you so much for working with this.  I've been playing with your recordings for days now.  I've learned a lot!
The only thing I'm stuck on is that after the solid is created with either of your approaches, the bumpins on the spout side have disappeared.   They should be hollow to receive a component that will slide over it on the top.
I know it may sound simple to you but I can't figure out how to cut them out again.  Push/pull isn't working -- i presume because its' an uneven plane to draw a sketch on or use the existing geometry.
Can you advise?
Attached f3d file is where I'm at.
jhackney1972
Here you go.  I will follow up with a Screencast of the process.  Model is attached.
jhackney1972
Since you retained the surfaces for the two notches, which gives you the right deep and size, it is a pretty straight forward process.  Take a look at the Screencast.  I am glad you did not remove those surfaces.
jimmberry
@jhackney1972i can't believe how easy that was.  You have no idea how much time i spent trying to figure that out.  Thank you so much!! 🙂
