Fillet with same outer and inner radius.
Hi all,
Is there any way how to create fillet like on the picture (this was imported from 3ds max into fusion) either using some parameters or a workaround? Ideally something that wouldnt be too time consuming to do, like using various lofts and whatnot.
Thanks!
etfrench
Define your profile, then use Sweep to apply it.
ETFrench
HughesTooling
Another way would be to leave the vertical edges sharp, add the fillet along the top edge then add the vertical fillets.
  Scrub that , doesn't work how I thought.
Mark
Mark Hughes
Owner, Hughes Tooling
