Cannot select array icons
jasonrucks
jasonrucks
There's likely a simple solution. This is less of a bug and more of a UI issue.
When I've created an array, sometimes I'm not able to select the icon to edit the array after creation. The icon is of a fixed scale, and on polar arrays, it's near the center axis. So when I try to select it, I select a nearby line from the array instead.
How can I select the icon instead?
HughesTooling
Have you tried left click and hold down until you get a select menu dialog? Edit Should add then right click and select Edit Circular Pattern constraint.
Mark
Mark Hughes
Owner, Hughes Tooling
jasonrucks
Wow. I had no clue that dialog box existed. I've wasted a lot of time by not looking this up before.
Thanks for your time, that solved the issue.
