Fillet only half of a line
Hey,
I am trying to make my design a little sleeker. I am playing with a standard extruded rectangle 6x3x3. Is there a way to break up the line essentially add a point so I can only Fillet the first 3 inches of the 6 inch length of the line.  Also any other good touch up tools besides fillet that you would recommend.
I have already attempted to go back into the edit sketch to add lines/points and it didn't work.
I_Forge_KC
You can do variable fillets like this...
Is that what you're looking for?
K. Cornett
Generative Design Consultant / Trainer
Hey,
I would like to make everything outside of the hole perimeter concave (the shaded part and below the blue). If I can make it a smooth transition that would be even better. I did not use the sculpt I know its very easy in that form. But I would like to do this with sketch compatibility. overall shape is a long rectangle
TheCADWhisperer
@Anonymous wrote:
.... (the shaded part and below the blue).
What is the significance if the image with red?  You give information about below blue, but no information about red?
Hey,
I am trying to make it concave like this that I made in sculpt but in sketch. This would represent the blue line. The Red shaded part was a more complex concave what I was trying to concave
