Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fillet on spline
7 REPLIES 7
Message 1 of 8
plasid2
245 Views, 7 Replies
Fillet on spline
How custom fillet object? Object is made by extrude spline, I try make full loop but cant, on 3th picture cut sweep disapear
7 REPLIES 7
Message 2 of 8
g-andresen
in reply to: plasid2
1. The profile is probably too wide for the upper part and leads to self-intersections.
2. Is the profile perpendicular to the path?
Please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 8
plasid2
in reply to: g-andresen
Thx reply I upload
Message 4 of 8
plasid2
Thx reply I upload
Message 5 of 8
g-andresen
As suspected, the problem is the self-intersection of the profile.
The simplest form is achieved like this:
günther
Message 6 of 8
g-andresen
Here is a more elaborate procedure:
1. The sweep profile is not perpendicular to the path.
This can be achieved by creating it on a plane on the path.
2. Instead of the "thickening " * I used a thin extrusion.
günther
*The surface element as the basis for the thickening is not to be deleted!
Message 7 of 8
TrippyLighting
Attached is a substantially more convoluted workflow where i took some creative liberties with the fillet at the pointy tip.
Message 8 of 8
plasid2
Thx guys for help
Technology Administrators
