Fillet on outer corner
Message 1 of 9
I am trying to create a scallop/fillet on the outer edge of a shape.  I want it to look like a ball end mill went around the edge of the part.  When I select fillet, it only lets me create a round.  To figure this out, I tried creating this on a basic extruded rectangle and still could not get it to work.  Should I be using something else other than the Fillet to try and accomplish this?  Do I need to do something special with my geometry?
Replies (8)
Message 2 of 9
HughesTooling
Try using Pipe from the create menu, set it to Cut and select the edge.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 9
JDMather
Can you do a Sweep Cut with a circle?
Edit: or Pipe as suggested.
Message 4 of 9
I tried the Sweep, but it will not go around the entire rectangle.  It only cuts out along the one edge that I select and it won't let me select any additional edges.
Message 5 of 9
JDMather
Can you File>Export and then Attach your actual *.f3d file here?
Did you try Pipe and hold the Ctrl key to select additional edges?
Message 6 of 9
The Pipe works as long as the shape stays as a basic rectangle, but my shape has scallops out of the corners as well. See attached picture for what my part looks like.  The fillet I am trying to create will go along the outer edge of the part.
Message 7 of 9
Here is the .f3d file.  I appreciate any help you can give me on this.
Message 8 of 9
JDMather
I fixed it up for you.  Smiley Wink
Hold the Ctrl key to select multiple edges for the path.
Message 9 of 9
Thanks.  That is exactly what I wanted.  I thought I tried holding down the Ctrl (Command Key on my Mac) to select the additional edges, but must not have.
