Fillet is working on one edge but not another.
Sprayfoamengineering
I am trying to create a similar fillet as the one shown below but for some reason I cannot get the part to create a fillet but it worked on the other side perfectly. This is my first post so I apologize if I posted this incorrectly.
Working fillet for reference:
This is the prefillet edge just so you can see its the same as the problem edge:
And the non working fillet edge:
Any help would be appreciated.
Potential solutions I have tried: squaring off the rounded corners of the square body connected to the cylinder, all different fillet types.
jhackney1972
You cannot place a fillet between two separate bodies.  Also, to combine these two bodies, you have to eliminate the clearance between them first.  Screencast will explain.  Model is attached.
John Hackney, Retired
I had a issue with the bodies not being connected therefore not able to create a fillet. It was just so small I couldn't see it till I did a section analysis and zoomed in. I would delete this whole post but I'm not sure how.
Thanks! This was exactly the problem I just couldn't tell till I did a section analysis.
