Errors with Draft and Sweep on Curved Path
tedbradley314
tedbradley314
Hi folks,
I'm extruding clay through a profile/die. I want the extrusion die to have a draft like a funnel so it compresses the clay into the final shape as it passes through the die.
I'm having a tough time modeling the funnel/draft. I first tried to create a draft feature and got the attached error. Then created my own draft profile and tried to sweep it along the profile path but got errors doing that as well. A bit of help would be very much appreciated.
Ted
etfrench
Here are a couple of ways you can work around the sweep limitations:
1: Do the sweep in small segments.  You'll still need to determine what to do with the acute angles where the sweep will intersect.  https://knowledge.autodesk.com/community/screencast/3b848b21-1beb-40f2-9244-10b43f96341c
2: Use the loft command.  You'll need to adjust the profile around the same acute angles: https://knowledge.autodesk.com/community/screencast/2b1c0162-a38a-4ef8-813a-6fc0dd915c6c
Here's the loft method:
ETFrench
HughesTooling
Could you keep the corners sharp then add fillets (constant radius rather than conical) after the draft? Only problem are the 2 splines, could they be fillets? If not I'll leave it up to you to create something you could sweep or loft. See attached file.
Mark
Mark Hughes
Owner, Hughes Tooling
tedbradley314
Thanks @HughesTooling.
Fillets seem to only work between two straight lines. I wasn't able to use them between a straight line and a spline.
Thanks @etfrench
I tried loft and it gave me a perfect result.
HughesTooling
@tedbradley314 Do you really need the splines? It becomes a lot easier if all corners are filleted. Actually it's only internal corners that are a problem. If you can use constant radius fillets, uncheck tangen selection and only select the faces, not the fillets. Screencast shows what I mean, don't know if this might be useful if you make a lot of these.
Mark
Mark Hughes
HughesTooling
Reading this again I see the problem, your part is a good example of why you should not fillet the sketch but fillet the body. In the first file I attached I created the body with no fillets, added draft then added the fillets. A lot more simple and quicker than filleting sketches.
First unfilleted body.
Then add draft then fillet.
Mark
Mark Hughes
tedbradley314
Thanks Mark! That looks like a great solution. Namely:
  • removing fillets from the draft and adding them to the body
  • creating draft by selecting individual flat faces rather than all faces including the fillets
I wish I would have seen that before I poured a couple hours into getting the loft to work. The challenge with the loft is that it doesn't know what reference points to line up when creating a face between the two profiles. So I had to add a ton of rails which was very time consuming, since every rail required it's only sketch on a unique sketch plane. But it did get a good result in the end.
