I have the design in the picture below I am trying to model. Please excuse my hand drawing skills! Its the bottom of a tank where all liquid should flow to the front center. I had a go at modelling it but could not work out how to joint the individual parts in such a way that they could be automatically extruded to the correct length and also aligned to the correct angles. Each joint is at odd angles and the angle iron sections do not meet nicely (which is fine in the real world).
I would like to have a single driving sketch for the angle iron profile, and for the overall length, width and front center depth to be adjustable so I can reconfigure the whole model by just changing those dimensions (either parameter or sketch dimension etc.)
I found that by making a component to hold the profile sketch, I can make each length of angle iron as a sub component from that sketch. But that means they end up as loose components that have to be positioned into place and extruded to correct length.
What I actually want to do is a slightly more complicated design, but I think if I can understand this problem I can apply it to make my final idea.
As an added bonus I also need to work out how to make a sheet metal shape to sit on the angle iron.
Any suggestions on how to do the angles, joints and automatic extruded lengths would be greatly appreciated.
