Fillet error on both sides of model but not individually
I have run into an issue where I get a error when I try to fillet both sides of the model, however no error on either side indevidually.
Project File: http://a360.co/22rTQaJ
Error: There was a problem combining geometry together.
If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident).
I found the issue in the orriginal extrussion. I had selected a face that incuded some projected geomatry braking the continuity of the spline.
