Fill Space Between Bodies - Boundary Fill Not Working
Message 1 of 11
I needed to make an angled and tapered hole in a solid body so I sketched the at the angle and taper I wanted, used revolve. to make the first body.  Then I made the second body from another sketch.  Now I need to join these two bodies and fill the space in between them.  Deleting the inner face of body #2 will fill the whole object in.  Boundary fill doesn't give me a cell option to fill the gap.  Is there a better way to construct this object?
Replies (10)
Message 2 of 11
TrippyLighting
Boundary fill needed defined boundaries. It cannot bride open gaps.
I have a feeling, however, that what you are trying is not the most efficient workflow.
BTW, there's a huge photo button when writing a post. try that the next tome you are posting an image 😉
Message 3 of 11
Any thoughts on a better workflow?  I'm a complete noob to CAD, we have a 3D printer in our chemistry lab and I've been making small upgrades to an instrument.
Message 4 of 11
TrippyLighting
Can you share your model (public link form data panel with download enabled) ?
Message 5 of 11
Johnc911
Is there a reason why you just don't cut a tapered circle extrude into the solid body?
Message 6 of 11
Johnc911
Message 7 of 11
Message 8 of 11
I didn't know I could enter a taper value like that from an extruded circle.  I need the overall hole to be at an angle through the main body as well.  Would I then just move the smaller face off centre from the larger circle?
Message 9 of 11
Johnc911
Then you would loft between two circles, like this:
Message 10 of 11
Awesome, thank you so much!  I thought there should be an easier way but when I googled how to make a tapered hole all the tutorials began with a revolved sketch.  Thanks again!
Cheers,
Message 11 of 11
laughingcreek
your working way to hard to achieve this shape.  And you shouldn't be using the move command AT ALL.   Can you hand sketch a cross section of what you want to achieve?
and a side note, the area indicated in pic is going to be problematic for 3d printing.
