Fill in the space between walls
duris.samuel
Message 1 of 20
duris.samuel
I'm sorry if this is really trivial question but: how can I fill in the space between the walls of my model, so when I try to print it, it won't come out as just a blank space?Snímka obrazovky 2023-11-14 120911.png
Replies (19)
Message 2 of 20
TheCADWhisperer
@duris.samuel
First thing I notice is that your Sketches 1-10 are not fully defined.
Then I notice that you have two Shell features in your design (normally there would be one and only one shell feature).
Would you be OK with starting over?
Message 3 of 20
TheCADWhisperer
Sketch1 is missing many many dimensions and not making use of obvious symmetry about the Origin.
Sketch1 is also missing geometry constraints.
Message 4 of 20
duris.samuel
Yes that would be awesome, thanks.
Message 5 of 20
TheCADWhisperer
@duris.samuel
Start a new part file.
Create a sketch rectangle above the origin and dimension as shown...
Add a Midpoint constraint between the middle of the bottom horizontal line and the Origin.
What the color of the sketch.
What do you observe?
Message 6 of 20
TheCADWhisperer
@duris.samuel
Sketch a second rectangle within the first rectangle and dimension as shown...
As with first sketch - add a Midpoint constraint between the bottom horizontal line of the second rectangle and the Origin.
Message 7 of 20
duris.samuel
the bottom line is now stuck to the center point even when i change the dimensions.
Message 8 of 20
TheCADWhisperer
@duris.samuel
Add a third smaller rectangle within the second rectangle and dimension as shown...
Add an Equal (=) constraint between one of the horizontal lines of the third rectangle and one of the vertical lines of the rectangle.
Now add a Midpoint constraint between the right side vertical line of the third rectangle and the right side vertical line of the second rectangle.
Now create a forth small rectangle and using only Equal (=) and Midpoint constraint make it equal to the third rectangle and placed symmetrically about the Origin.
Attach the file here for next set of steps.
Message 9 of 20
TheCADWhisperer
I don't see any dimensions in your image.
Already you are not following my explicit step-by-step instructions?
Message 10 of 20
duris.samuel
Okay, here is the file. I'm sorry that i'm a bit slow.
Message 11 of 20
TheCADWhisperer
@duris.samuel
All of my instructions were to create a Rectangle.
Your second "rectangle" does not appear to be a Rectangle (did you not observe the difference between my image (color) and your screen)?
My instructions were to make the fourth rectangle Equal (=) to the third rectangle, not do add any dimension.
Message 12 of 20
duris.samuel
Message 13 of 20
TheCADWhisperer
@duris.samuel
I haven’t forgotten about you - I will be away from my computer for a while.
Message 14 of 20
duris.samuel
Thank you for your time. I will wait.
Message 15 of 20
TheCADWhisperer
@duris.samuel
Oops, well this time I did forget about you...
Extrude all 4 rectangles a distance of 206
Turn the Visibility of the sketch back on
Extrude - Cut the area inside the remaining 3 rectangles as shown...
OK
Oops, I forgot a step - no trouble.
Drag the Timeline marker back before this second Extrude feature.
Hide Sketch1
Add a 5mm Fillet to the 8 edges shown (you can pick them right through the model...
Be careful to select Edges and not Faces.
Now drag the Timeline marker back to the end.
I see another mistake that I made that we will take care of in a few minutes.
Shell the part selecting the top face to remove...
Attach the file of your progress so far.
Next we learn the real power of history-based modeling as a time machine going back in time.
Message 16 of 20
duris.samuel
Hello. Thank you again for helping me. Here is the file.
Hope you have a great day.
Message 17 of 20
TheCADWhisperer
@duris.samuel
Keep in mind that I am not familiar with your geometry.
I made a mistake early on - but we will say that I did it on purpose to demonstrate how to edit a sketch. Yeah, that's the ticket to redemption...
Edit Sketch1 and select and Delete the two Midpoint constraints...
Click and drag the two small rectangles to the other side of the vertical lines...
Put the Midpoint constraints back in so that the rectangles are on the correct side.
Now Edit Extrude2 and CTRL (CMD on Mac) unselect the two small rectangle profiles.
Should be back to where we were...
Message 18 of 20
TheCADWhisperer
@duris.samuel
Now drag the Timeline marker back to before the second Extrude (Fusion is a Time Machine from the movies).
Start a New Sketch on the top face...
Select the top face and mash P for Project.
Click OK
Finish Sketch and then select the Hole command...
In the HOLE dialog box make sure to select the Multiple Hole option
Set the bottom type and the depth that YOU want.
Drag the Timeline marker back to the end.
From the MODIFY drop down select Offset Face...
Select the four cylindrical faces shown and enter a distance of -.25
Attach your progress here.
Before we go further - can you explain the purpose of these holes?
If you are going to use for screw fasteners - exactly what are the specifications of the fasteners that you will use?
Message 19 of 20
duris.samuel
The holes are for screws for the lid of the box, but I dont have any specific ones in mind yet. I was thinking I could just screw them right into plastic once it's printed.
Message 20 of 20
TheCADWhisperer
@duris.samuel
I am going to be unavailable for the next 9 days.
Bump this back to the top if I forget about it.
