Fill in shell to make a solid mesh
mstevens12269
Observer Observer
Message 1 of 9
mstevens12269
Observer
Observer
I will start by saying I am learning stage of fusion but could use some help with a project.  I have a mesh scan of an object.  I am trying to figure out how to make it solid.  I have watched a couple tutorials but can't seem to figure it out.  Any help would sure be appreciated.  the screenshot shows the area I am trying to fill.  I have also included the actual mesh file.
Thank You in advance for any help.
Replies (8)
Message 2 of 9
TrippyLighting
@mstevens12269 wrote:
I will start by saying I am learning stage of fusion ...I have a mesh scan of an object.
That's a pretty bad start into CAD. My recommendation would be to go through the free tutorials Autodesk has created to help new users here:
Meshes are NOT want CAD software (not just Fusion but any CAD software) uses to represent 3D geometry.
CAD software uses analytic geometry and NUBS surfaces usually stitched into a BRep to represent geometry.
As such you will find that meshes can be difficult to work with in Fusion.
That is particularly the case if you want to make it a solid body and work with it with Fusion's native solid modeling tools.
Once you have this "filled id" what do you want to do with the model?
Message 3 of 9
mstevens12269
Observer
Observer
I am going through the tutorials.  I will be 3d printing it to make a mold once I figure it out.
Message 4 of 9
TrippyLighting
Are you using a paid, or a free subscription?
The paid subscription allows you to use the Organic mesh conversion, which would work well for this part.
The attached model shows the workflow.
If you use a free subscription, you can use a similar workflow in Autodesk Meshmixer, which is designed to work directly with triangulated meshes.
Message 5 of 9
wersy
You can print it as it is. You don't need a solid.
Message 6 of 9
mstevens12269
Observer
Observer
I am using a free version currently but do have meshmixer and will give it a try.  I realize I can print it as is but structurally it won't hold up to the mold making process.
Message 7 of 9
TheCADWhisperer
... do have meshmixer and will give it a try.
You will not get anywhere.  The mesh is poor quality.
The only real solution is to use the mesh only as reference in remodeling proper geometry from scratch.
Message 8 of 9
wersy
Maybe it would help if you use support.
Message 9 of 9
mstevens12269
Observer
Observer
thank You,
Shows I have a ton to learn.
