I'm new to fusion and trying the Form functions.
I have a chair bridged to a Plane but there is a hole underneath, I have tried Fill Hole by selecting the edges of the plane but it doesnt let me.
Can anyone show me the correct way to do this?
Solved by TrippyLighting. Go to Solution.
Solved by jeff_strater. Go to Solution.
I was able to get the hole filled using the Face command. It required some repair, though - one of the original faces seemed odd to me, so I deleted and re-created it. Then, I had to go in and do an Auto Repair, which fixed the model. Then, I could Crease the outer edge to get close to, but not exactly what I think you are after. I'm not sure whether I can get the final result, but maybe these techniques can give you some hints. Alternatively, you can fill this using the Surface environment.
The repaired model is attached for reference
screencast:
