Sorry for the non-descript title; what seems to be the issue is that when trying to load an instance of an assembly I've been working on only 1 machine seems able to do so. All attempts to open (both on the App and on F360 on another computer) fail. In the instance of the app; the app force closes without warning and is unable to load any aspect of the file/assembly. In the case of the computer I receive the following message:
"The file you are trying to open is currently being saved by User [my name]. Do you want to open a previous version instead?"
If I click no, F360 stops responding and shuts down.
I appear to have no problem opening the file on one particular machine, however I've noticed 2 things on that machine. 1) I am unable to update to the latest fusion360--emailed the stream.log to Autodesk; and 2) I am unable to cloud render the file as the render states something along the lines of "There is an issue with the file."
So how do I remedy this? Any thoughts? Anything that can be done on the Server side to remedy/fix? Thoughts?
Edit: Trying to select "Yes" to open a previous version creates an error of unknown exception. Saving an iteration on the machine that is able to load it, then closing fusion down on that particular machine, followed by attempting to open said version results in the error already described. Attempting to open or promote the previous version of the file results in an error as well.
