How to make a zero thickness face or wall?
majianjia
majianjia
I wants to build a thickness wall that use for 3D printing. Zero thickness wall is a easy way for 3D printer to print a single line shell.
The zero thickneess face looks like the surface of the wing upper.
Jianjia
Hi, if you switch over from the Model to the Patch environment, you can create surfaces there.
Hope that helps!
Niels
majianjia
Thanks Niels, it dose help!
Jianjia
