File is missing progress and entities
marc7X3XJ
marc7X3XJ
I was to look at and finish my first project in Fusion 360 the other day and when I opened up the file there were only 2 of the 4 components in the file. I know that I had worked on the project on multiple computers and the components were saved at at least a couple points in time but it is as if I never created the 3rd and 4th components. I hadn't worked on this project in a couple of months because I was sidetracked with a more current project. Has anyone else had a problem like this before? Is there any sort of master backup somewhere that I am not aware of? They are not complicated pieces and I can recreate them in a couple of hours but it would be nice if I could start where I had left off that last time that I worked on it.
Than you,
Marc
innovatenate
Autodesk Support
Autodesk Support
Hey Marc,
Have you tried looking through all of the versions saved in the cloud? Perhaps the two components were accidently removed from the current version? Is there any chance the components are not visible and that is the problem (see the light bulbs in the browser)?
Are there any error messages or anything when you open the design?
Nathan Chandler
Principal Specialist
