Assembly Joint - both Concentric and Coincident
Former SolidWorks user, used to mating a screw with a coincident mate (bottom of cap screw head to top of hole face) and a concentric mate (screw centered in hole).
In Fusion it seems I can only apply either a face to face joint or a concentric joint?
How do you go about mating a screw to a hole?
Any help appreciated
Beyondforce
Hi @Anonymous,
I can show you hot to, If you attach the file. But in Fusion we use a Rigid joint in that case, since it doesn't make sense to animate a screw. If you built the cap in place, then just use the As-Built Joint - Rigid.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
