Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
figure out miter angles on complex volume
5 REPLIES 5
201798RLR3V
322 Views, 5 Replies
I have these complex volumes:
I want to make these out of 22mm plywood. Is there a way to have fusion360 figure out the miter angles I have to cut at?
Labels (4)
5 REPLIES 5
Warmingup1953
in reply to: 201798RLR3V
Do you mean every face is cut from a sheet of 22mm Ply at 1/2 the angle between the adjoining face?Screen Shot 2023-01-11 at 9.48.40 pm.png
The Measure tool will give the the angle...Screen Shot 2023-01-11 at 9.55.22 pm.png
davebYYPCU
Measure the face angle across the relevant edge.  Divide the answer by 2
Might help....
201798RLR3V
in reply to: Warmingup1953
Yes that is exactly what I mean. However is there a way to not have to create all the sheets myself in a sketch but extrude it in a way and have fusion do the angles automatically?
laughingcreek
various ways you can model it, but not an automatic way.
Warmingup1953
Not that I am aware of. Your examples don't look too hard...Repetitive of course! The hardest thing will be cutting the angles less than 45 degrees! Will you CNC cut the "blanks" and then panel saw the angles as needed? (..add 1/2 a degree to allow for glue.)
