Feature Request : RE: Redefine Sketch Plane, etc.
RogerInHawaii
RogerInHawaii
When you select to redefine a sketch plane all you get is a dialog where you can select a DIFFERENT plane.
It would be SO, SO helpful if that dialog showed the name of the current plane that's associated with the sketch.
That kind of "show me what's already selected" feature would be so very helpful on many different similar dialogs.
Go to edit an Extrude, Revolve, Sweep, or Loft feature and it would be helpful for it to show the name of the Sketch(es) that was/were referenced.
What we currently see:
Suggested improved dialog:
davebYYPCU
Redefine sketch plane - has an inbuilt disorientation routine, never arrives in an intuitive orientation - usually mirrored or inverted or both.  Not a tool to recommend.
The other points have been implemented.
Edit any of those features, including Loft, all sketches used in the feature are highlighted blue in the Browser.
Might help....
