Feature pattern taking too long
mschoonmaker
mschoonmaker
When I select a previous (successful) rectangular pattern feature (green arrow), I get some extended wireframe entities (red arrows) I don't know about. How can I correct this?
jeff_strater
@mschoonmaker, can you share your model here?  We'd need to take a look to be certain.  Offhand, I'd say that this might be a sketch that is invisible, but is referenced by the pattern.  When you select a feature, Fusion highlights things referenced by that feature, even if they are invisible.  But, if you share the model, I can let you know for certain.
Jeff Strater
Engineering Director
mschoonmaker
sure. here's the public link: https://a360.co/2v3VoSa
Separately, I observed that the title of the post is not correct. this is my first forum post, and I think I clicked on another forum post title and it seems that it was dropped in. Not a big deal, but thought I'd clarify...
mschoonmaker
I used your suggestion about another sketch and sure enuf, there was the problem. All set, thanks for the clue!
