FEA simulation on a solid body with a defined infill density and geometry
Hello experts,
I am interested in doing a static stress simulation on a body with a set infill density and geometry. I am hoping to compare the results with simulation results for the same part set at 100% infill.
Currently I have a 7mm thick shell (shown below) and I have run FEA sims using solid polycarbonate (assuming 100% infill by default). I have not found a way to adjust infill settings for the solid body.
Using this forum, I found Slic3r, which can help me use a .stp file to assign a 30% infill density with a honeycomb structure. I would like to know if that .stp file can be exported back into fusion 360 to run a simulation.
If it is not possible to test the part with a selected infill density, are there any steps I can take to make the simulation results mimic that of a part with 30% infill density?
Lastly, I also have the exact dimensions of the honeycomb structure I am expecting to be the infill. Would it be difficult to add the honeycomb cell-by-cell to replace the solid body interior?
Looking for any and all recommendations! You guys are heros, thank you.
Max
