FEA simulation on a solid body with a defined infill density and geometry
Hello experts,
I am interested in doing a static stress simulation on a body with a set infill density and geometry.  I am hoping to compare the results with simulation results for the same part set at 100% infill.
Currently I have a 7mm thick shell (shown below) and I have run FEA sims using solid polycarbonate (assuming 100% infill by default).  I have not found a way to adjust infill settings for the solid body.
Using this forum, I found Slic3r, which can help me use a .stp file to assign a 30% infill density with a honeycomb structure.  I would like to know if that .stp file can be exported back into fusion 360 to run a simulation.
If it is not possible to test the part with a selected infill density, are there any steps I can take to make the simulation results mimic that of a part with 30% infill density?
Lastly, I also have the exact dimensions of the honeycomb structure I am expecting to be the infill.  Would it be difficult to add the honeycomb cell-by-cell to replace the solid body interior?
Looking for any and all recommendations! You guys are heros, thank you.
Start with the .stp file import. If the geometry exports properly...then fusion should be able to handle it. But if it literally shows layer lines...that's going to be a big challenge to mesh and may require some pre processing work in the simplify space.
A few notes:
-this will have areas with a high aspect ratio so it will be challenging for the mesher. Make sure you have a fine mesh for decent accuracy.
-3D prints can fail from layer adhesion and other artifacts which would occur at a lower value than ultimate strength.
-make sure to let us know how the import and simulation goes!!! This is a question a lot of people have and I've never personally tried it. But I'm really curious about it now!
After setting the infill density and infill type in Slic3r, I exported the .stl (no option for .stp export I see in Slic3r) back into fusion.  I had to convert from mesh to BRep.  After using the section analysis tool, it appears that the body is still solid, just with a ton more faces.  There is a picture shown below.
If I had the .stp file from Slic3r would it change the result of the import to fusion? Do you know how to export a .stp file from Slic3r?
In response to your note about ultimate strength - I have read that testing at 50% ultimate tensile strength accurately accounts for any losses during the 3D printing process.  Is there a way I can set this in value in my simulation?  I found a place to set my safety factor to ultimate tensile strength (screenshot below).
Thanks for your help! I'm learning lots.
