FEA - find a specific FE using ID
Is there a way in Fusion 360 to find a specific finite element based on its ID? Report on mesh quality in Solve -> Solve Details does not make much sense otherwise...
Greetings, Marko
John_Holtz
Autodesk Support
Autodesk Support
Hi Marko,
You cannot locate specific elements (or specific nodes) in the Fusion interface.
The Fusion interface is greatly simplified compared to the output of the solver. So there are things reported in the solver details/output that cannot be done in Fusion. For example, error messages may suggest changing some parameters, but the parameters are not accessible by the user (to keep the process as easy as possible).
If you are having a specific problem, please feel free to post some details.
I should mention that the same solver used by Fusion is used by other products, such as Nastran In-CAD and programs provided by other companies.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
John Holtz, P.E.
Global Product Support
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
