I am trying to get rid of the face lines on a pipe design. I created the pipe by using the pipe function on a sketch line. I tried merging faces under surface but it gave me the error "Failed to merge surfaces". Is there a way to create this without those face lines?
Thanks in advance!
Solved by HughesTooling. Go to Solution.
Thank you for your answer, but it's not only for visibility I need it to be one single face, how can I accomplish this?
Regards
Loft might work but you'll need the centre line path and circular sketches both ends. Just did a quick test on a 2d profile and got a single surface, don't know if it'll work with your more complex shape.
Mark
Mark Hughes
Owner, Hughes Tooling
One more note, you can't create a hollow loft so you'll need 2 lofts or loft and shell.
Mark
Mark Hughes
why do you need this to be a single face? It might be possible, but I'm not sure I understand why this is important. Most CAD designs are composed of multiple faces, and as long as they are tangent continuous, I can't see any benefit to one face over many.
The reason for this is that I'm planning on running a CFD on this design and having a single face simplify the creation of interferences between fluids.
Thanks for reading!
Thanks, @Anonymous . Seems like a good reason, thanks for the explanation!
