Failed to merge surfaces (pipe surfaces)
8 REPLIES 8
Message 1 of 9
1179 Views, 8 Replies
I am trying to get rid of the face lines on a pipe design. I created the pipe by using the pipe function on a sketch line. I tried merging faces under surface but it gave me the error "Failed to merge surfaces". Is there a way to create this without those face lines?
8 REPLIES 8
Message 2 of 9
Marco.Takx
Hi @Anonymous,
If it is only for visibility you can press Ctrl.+4 to make all shaded.
Those edges are tangent edges and can't be deleted.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 9
in reply to: Marco.Takx
Thank you for your answer, but it's not only for visibility I need it to be one single face, how can I accomplish this?
Regards
Message 4 of 9
HughesTooling
Loft might work but you'll need the centre line path and circular sketches both ends. Just did a quick test on a 2d profile and got a single surface, don't know if it'll work with your more complex shape.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 9
One more note, you can't create a hollow loft so you'll need 2 lofts or loft and shell.
Mark
Mark Hughes
Message 6 of 9
jeff_strater
why do you need this to be a single face?  It might be possible, but I'm not sure I understand why this is important.  Most CAD designs are composed of multiple faces, and as long as they are tangent continuous, I can't see any benefit to one face over many.
Jeff Strater
Engineering Director
Message 7 of 9
in reply to: HughesTooling
This worked!
Thank you very much
Message 8 of 9
in reply to: jeff_strater
The reason for this is that I'm planning on running a CFD on this design and having a single face simplify the creation of interferences between fluids.
Thanks for reading!
Message 9 of 9
jeff_strater
Thanks, @Anonymous .  Seems like a good reason, thanks for the explanation!
Jeff Strater
