Failed to Boolean Bodies Together Error
I am having an issue using the combine tool. I am trying to make a puzzle shape but keep getting a Failed to Boolean Bodies Together error. I have done it successfully using a different .dxf file, but cant get this one to work. I have attached the files. If anyone could help I would really appreciate it.
Thank You!
laughingcreek
It looks like your originating mesh (before you converted to a brep body) had some issues.  In the screen cast I show one location that had multiple faces overlapping each other, essistally occupying the same space,  This is what's causing combine to fail.
try repairing the mesh file in something like mesh mixer first.  You can probably repair it with just the automated inspector tool.
laughingcreek
oops for got the screen cast
