faces became flat when using bridge tool..
Message 1 of 14
Following the tutorial on youtube, when using the bridge tool (5:20), setting the faces to 6 or more(default is 3), hit ok, the body faces became "flatten" and not smooth, I'm guess this might be an display issue and could be solve by some sort of setting, can anyone tell me where to locate the setting or what dose that mean?
When the faces set to 3 the result is ok.
Replies (13)
Message 2 of 14
colin.smith
Hi @Anonymous, that is strange.  When you get the "box mode" that usually indicates that something in the model isn't closed properly - but that doesn't make sense.
Have you tried changing the model to smooth mode manually?
Go to Sculpt > Utilities > Display Mode and select the smooth mode.
Regardless, it looks like a bug.
Can you share the file with me?
I did a quick test here and it seems fine.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Alias Create VR (aka Project Sugarhill)
Automotive & Conceptual Design Group
Message 3 of 14
Hello Colin
Yes I did choice the display mode under utility pull down menu but it did not work. Here's my original file for your reference:
http://a360.co/1Vt8n59
After I read your reply I opened a new file and the same thing happened, and you were right, I know there must be something wrong in my model but I just could not sense it:
Above screenshot was set to 3 faces, which ended up normal.
Then I set the faces to 6.
And this happend again..
The display mode setting did not help here, here's the link FYI:
Before bridge:
http://a360.co/1UbfsCi
After bridge with 6 faces applied:
http://a360.co/1ZaWnnT
Tanks for your kindly helps.
Raymond Lin
Message 4 of 14
PhilProcarioJr
@Anonymous
I don't know how you ended up with them but you have faces on top of each other. Once I found and deleted the faces it shows in smooth mode and converts fine. Here is the fixed file.
If you want to see what I meant select a face and hit the delete key if it makes a hole that face is fine undo and look for it not to make a hole.
Fixed:
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 5 of 14
PhilProcarioJr
@colin.smith
Your team should add an option to the T-Spline repair tool to look for duplicate overlapping faces as I have run into this problem at least 3 times now. An auto fix would be nice for conditions like this. The only reason I knew it was Duplicate faces on top of each other was because the repair tool reported star points and he didn't have any in the problem areas.
Phil Procario Jr.
Message 6 of 14
Thank you, I looked for those overlaped faces and deleted them, this is the closeist result I could do.
I went on the youtube and looked how to use the bridge tool properly but I did not see anything I missed when using the tool, I checked the faces before I created the bridge and those faces were all good, any suggest how I can be awared to avoid situations like this?
Raymond Lin
Message 7 of 14
PhilProcarioJr
@Anonymous
Unfortunately I don't know how it happened and for me it is rare so I haven't been able to pin it down on how or why it happens. Could be a bug, the dev team will have to look at your file and see if they can figure it out. Sorry I can't be of more help then that. Your last picture shows me you still have some duplicate faces in your model, but at least you know WHAT to look for now.
Phil Procario Jr.
Message 8 of 14
Thank you very much!
Message 9 of 14
PhilProcarioJr
@Anonymous
Something else I would like to point out. See the dark thicker black lines around some of the faces? This shows an open edge. You always know whats wrong when you see this, it either means you have unwelded edges or duplicate faces. Someone new to the program wouldn't know this that's why I'm pointing this out.
I circled them in green.
Cheers
Phil Procario Jr.
Message 10 of 14
Haha, I noticed that but worried too easy to ask it, just figured out how I could merge them, thank alot!
Message 11 of 14
colin.smith
Hi @Anonymous, I'll download the file and take a look.
@PhilProcarioJr - thanks for the assist.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Message 12 of 14
colin.smith
Hi @Anonymous,
I think I figured out the problem that caused this and it is related to the symmetry.
I noticed that in your screen shots you had symmetry on both parts and I assume you had mirrored symmetry also.
The combination of all the different symmetry conditions seems to confuse the bridge tool.
You will see in my example that the preview didn't follow the curve so I had to rotate it in to the proper orientation.
When I did this the preview flattened out in the middle of the part and then looked normal again.
When I hit OK in the bridge command I ended up with a similar result to yours.
Now after clearing the symmetry and repeating the bridge command:
I'm going to submit this to the TSplines team.
Colin
Colin Smith
Sr. Product Manager
SketchBook
Message 13 of 14
Hi Colin
Thank you, but I don't get this "clearing the history", how can I do that in Fusion 360?
Thanks.
Message 14 of 14
colin.smith
My appologies, I meant to clear the symmetry, not history.
I updated my post with this correction.
Colin
Colin Smith
Sr. Product Manager
SketchBook
