Faceplate layout
Faceplate layout
Message 1 of 15
Faceplate layout
Thought I would use F360 to layout the faceplate for an enclosure and I am struggling!
I have marked some socket holes on the left hand side of the faceplate, and need to mark out a cutout for a DB25 socket
on the opposite side - my problem is marking out the cutout/mounting holes relative to the right hand side of the panel?
The DB25 cutout is not rectangular, one side is larger than the other
Even being able to draw a vertical construction line 16mm in from the right hand edge would be a start...
(I don't have much F360 experience)
Chris
Replies (14)
Message 2 of 15
TrippyLighting
Attach a screenshot, or screencast or share your model if you want help.
Message 3 of 15
Ok, here you go?
I am trying to add the cutout in the second image into the the sketch shown on the first image - on the right hand side (vertically) ?
Spaced in 16mm (centre line) left from the right hand edge?
Ultimate objective is to print a template to help me cut the panel out?
Chris
Message 4 of 15
davebYYPCU
Dimension the centre point of the rectangle, 16 mm from left edge,
the only hard part is the angle dimension, fillets last.
Message 5 of 15
Sorry, I don't understand?
I want the new cutout to be 16mm from the RIGHT edge?
I placed the four socket holes and power connector cutout from the left edge,
I want the DB25 connector spaced from the right edge?
As the attached, very rough drawing but need to mark it out with the right hand
edge as the datum?
Chris
Message 6 of 15
davebYYPCU
Draw a line between the centres of the holes, dimension it 16mm from right hand line.
i notice there are no dimensions in the pics, presume they are there when in edit sketch mode, you need them for what you are trying to do.
You can always down load a socket from Grabcad, use it as a cutter.
Might help....
Message 7 of 15
TrippyLighting
@Anonymous have you looked through any of the video tutorials in the Support and Learning section ?
Message 8 of 15
Yes, I tried this - I can measure between the construction line and the right hand line, but cannot adjust the
measurement to be correct - I have been in this position before, think I am doing something wrong creating
the dimension, but I will go back and look through the tutorials again as someone else has suggested?
Yes, when I edit the sketch I get dimensions, but when I draw a vertical construction line the length is
dimensioned but not the distance from the right had edge?
I have clearly missed or misunderstood something...
Chris
Message 9 of 15
Looks like I have a solution, perhaps...
Draw a vertical construction line,  use D = Dimension (not Inspect | Measure!) to measure distance back from right hand line (16mm)
Draw another circle on construction line and dimension to be the correct distance (16mm) up from bottom line and so on - for all the
required circles (other mounting hole and corners of cutout)
Seems a dreadfully clunky way of doing it, would have taken me half the time in a CAD package so there must be a better approach I have
yet to discover!
Message 10 of 15
TrippyLighting
@Anonymous wrote:
... use D = Dimension (not Inspect | Measure!) to measure distance back from right hand line (16mm)
D is used to define dimensions. Inspect->Measure is used to measure dimensions.
Given your lack of basic understanding I'd refrain from making statements about other CAD packages.
Message 11 of 15
I apologise if I have offended anyone!
I did end my post with a comment about my lack of understanding, it was not meant to be a
criticism about Fusion 360, far from it
Message 12 of 15
TrippyLighting
No worries. I apologize for being grumpy!!
Are you designing a complete device, or just the front plate and are you doing this more often ?
If so I’d approach this differently.
Message 13 of 15
chrisplyler
Message 14 of 15
This project is not really a 3D model - it is simply to layout cutouts to
install sockets and switches in a (rather expensive!) enclosure so I do not
want to cut holes in the wrong place
It is a one-off, I am a model engineer and this is a case for my home build
CNC controller.
I started using Fusion 360 when I bought a couple of 3D printers, but
perhaps it is overkill for panel layouts
Message 15 of 15
chrisplyler
Fusion is perfect for that.
Depending on your CNC methods, you can either prepare the CAM right in fusion too, or you can right-click on the sketch in the browser tree and select Save as DXF to output a 2D file with the edges for your CNC controller software to use.
