Extrusion partly dissapeares when I change parameters.
I am trying to make a parametric design I can use multiple times with different dimensions. When I change certain dimensions a part of my extrusion disappears. I noticed this happens when the horizontal construction-line crosses the corner of my object. You can see what happens in the screencast.
Is there any way to fix this?
thank you.
TrippyLighting
Here is the file. When I set ph_length to anything more than 22mm it stops working.
