Im fairly new to the Fusion 360, using it for the first time...
I've imported two spheres from inventor to fusion, the inner sphere and the outer sphere. And what i want to do is to extrude one triangular component which would be the in between two spheres. I tried to draw the lines but somehow it only extrudes one face, and does not follow the path of the lines, or in other words it doesnt extrude from inner spheres face to the outer spheres face...
Here is some pictures of what i mean :
1st picture, extrudes only with the path from inner spheres triangular face, and does not allign with the outer spheres triangular face.
2nd picture: same as the 1st picture, extrusion fallow the wrong path.
3rd picture: the triangular face needed.
4th picture: Ive drawn the lines (where the black dots are) in hope that it would help the extrusion, but it didnt.
Any idea how i could achieve this kind of extrusion ?
Thanks in advance !
Solved by PhilProcarioJr. Go to Solution.
