Extrude sketch concentrically into cylinder
harperrhett
harperrhett
Hi all,
I'm trying to find out how to create an extrusion that extrudes to the shape of an object. For instance I have this cylinder here with a circular sketch:
The circular sketch was made on a tangent plane, and I want to extrude it a small amount into the cylinder but maintain the original face of the cylinder. If I extrude it now, it will create a flat inset plane, but I want it to be curved like the cylinder. Is there some way to wrap the sketch and then extrude it?
Thanks 🙂
g-andresen
please share your design to take a look at.
Maybe "Extrude" with option "From/To object" might help.
günther
jeff_strater
@harperrhett - From Object in Extrude is the way to go here.  One warning, though.  There is a bug with From Object and tangent sketch plane:  extrude-only-extrudes-part-of-selected-profile , so it helps to offset the sketch plane a bit.  But, this will result in the geometry you are after:
Jeff Strater
Engineering Director
MRWakefield
Hi Jeff, this is what I was playing with when I came across the bug you're referencing.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
harperrhett
Sorry for the late response! I am familiar with to object, for some reason I totally overlooked from object, thanks for the help! I am having trouble with that bug though, only half of my sketch is extruding, I'll have to take a look at the workarounds.
