Hello!
I am creating clay cutters in Fusion 360. Think cookie cutters, but for clay to make earrings out of it.
This is my first post, so if you need extra information, just let me know. I didn't really know what to include.
My designs are super basic, but it works fine for me.
The only thing I can not find is how to create smooth walls that are 3-4mm at the bottom and 0.4mm at the top (cutting edge).
When I create a sketch I make an offset for the sketch 3 times (0.4mm, 1,5mm, and 3mm) and I extrude in the same order at 10mm, 5mm, 3mm.
Sketch (inner lines) with offset
Extrusion: Which I don't like
What I want to achieve are walls that are smooth from top to bottom, like this:
thicker bottom on one side or thicker on both sides.
I tried the filet tool. This makes the 'bump' more rounded, but it's not entirely what I am looking for.
When I try the chamfer or draft tool I get error messages (and I don't know if this is the right tool to achieve this look)
This is the max setting I could get using chamfer. But again, not sure if I'm doing/ using it right.
Thanks!
