Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Extrude "To" is missing now.
cristiprefac
Message 1 of 11
cristiprefac
I noticed the Extrude "To" Extent option is missing now. Instead, you can indeed click the face to extrude to, but it only reads the explicit distance and sets it, it's not "parametric" anymore, which is a very big drawback when designing stuff and you need to go back and adjust dimensions.
For example, I extrude a face "To" another face, then go back one step in timeline and offset the face I extruded to. When I get at the end of the timeline, my original extrude "To" doesn't change, since the distance is explicit and doesn't take into account the fact that the face I extruded to has an offset now. I hope this makes sense.
Replies (10)
Message 2 of 11
daniel_lyall
yep I did it a few different ways and each time the presspull would not move to the offset face it stay at the original presspull position.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 11
Beyondforce
Hi @cristiprefac,
Is that what you are looking for?
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 4 of 11
daniel_lyall
@Beyondforce you missed one step offset face, the way you showed can not always be done sometime you have to use offset face.
that's where the problem is.
what you showed is correct and what the op should do but it's failing if you need to offset a face that is a presspull to face
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 11
Beyondforce
Will you please make a screencast?
Ben Korez
| YouTube
Message 6 of 11
cristiprefac
Yes, thank you! 🙂
Message 7 of 11
jeff_strater
I think this is working correctly, at least in the simple case I tried.  The one thing I noticed in what @daniel_lyall said was that he was using Press/Pull.  The Press/Pull command can sometimes do an Extrude, but other times will do a Offset Faces, depending on what is selected.  This is why I don't like Press/Pull at all - I'd rather know what command I am executing and just use that.
Here is a screencast:
The other thing that can be confusing sometimes is that Extrude also supports "Snap to Face" when it is in "Distance" mode.  This is a vestige from Direct Modeling, where there is no associative "To Object" Extrude.  In this mode, yes, snapping to a face just sets the distance to that face, does not allow an offset, and does not conform the Extrude to match the shape of the face.  So, be sure you have selected "To Object" if you want it to be associative.
Here is another screencast showing face snapping:
Hope this helps
Jeff
Jeff Strater
Engineering Director
Message 8 of 11
daniel_lyall
@Beyondforce will do in an hour got school run to do
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 11
Beyondforce
Don't understand the question?
Ben Korez
| YouTube
Message 10 of 11
daniel_lyall
@Beyondforce it's not a question
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 11
daniel_lyall
now here is where it fails what is the wrong way to do it now, and I show the fix.
including a offset face
Daniel Lyall
The Big Boss
Mach3 User
