Extrude, Loft or Sweep multiple Faces to Multiple Endpoints
I am looking for help with how to design something, and my brain isn't quite ticking the boxes.
I have a series of 6 pipes coming from a holder and I want to extrude each of these along a unique path until it hits a given point on a surface.  The pipes come out of a holder in one plane, See 6FibreHolder v8.png, and are to be bent around and gathered in a pattern I've laid out, see construction lines/points in 6FibreHolder v8-2.png.
The context is the real device has 3D printed holders and the long pipes are plastic fibre optic cables - which in the real set up are bunched together into a circle packing.  I am looking to draw that leading and bunching of the fibres.
Many thanks in advance,
Euan
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
Attached.
laughingcreek
If your just trying to make it LOOK decent, then you can just loft the profiles together.  tangent for the end of the fiber, and directional for the sketch profile.
wmhazzard
Use a loft with guide rails or simple lofts if they don't need to be exactly like the real world.
MoshiurRashid
Try sweep command with guided rail. See what happens
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
