Section view detail: diameter dimensioning
Hi
I need to draw a detail view of cross section of a big diameter ring with small, but complicated cross section area (O-ring grooves, threads,...etc)
May I anyhow dimension it via diameter dimensions instead of annotations?
(For example (attached), how to dimension inner diameter in detail G?)
Or, if I HAVE TO use annotations - is it possible to include variables' values in annotation text?
Thx in Advance
jhackney1972
Fusion 360 drawing environment does not have the Linear Diameter dimension ability yet.  I suspect in the future it will similar to the functions you will find in Autodesk Inventor.  As you say, you will probably have to resort to view annotation.
John Hackney, Retired
