Extrude from sketch works, loft between sketches doesn't.
hugowitsenburg
hugowitsenburg
I'm designing a 3D printable part (will be a 3D printable RC F1 powerboat). I sketched various sections to loft through. The sections are all similar, of course. This is one of them:
[img]https://i.imgur.com/XEH0Hgo.png[/img]
The round hole is a constant through all sketches and will house a carbo rod for strenght and alignment when I glue various printable sections together.
From the hole center, you see two very narrow slits, 0,1 mm wide, go out almost to the outer shell. I made those to trick the slicer and printer. When I slice this without infill, top and bottom, I get a nice part:
[img]https://i.imgur.com/QSdCLhN.png[/img]
With the slit so narrow, it actually prints as solid ribs. I extruded one sketch, exported as STL, sliced and printed it. It works.
But, when I want to loft these sketches together, it only takes the outer shell. It completely ignores the round hole and the slits. So, my plan doesn't work. Can I get Fusion to loft including the round hole and slits?
Cheers,
Hugo
davebYYPCU
Loft complete solid.
Followed by (many?) Loft / Extrude cuts for internal detail.
Fusion Loft has never been able to do the whole thing in one shot.
Might help….
hugowitsenburg
Thanks, that is indeed what I resorted too. Weird thing, this lofting...
Cheers,
Hugo
