Extrude from Offset - Bug ?
mhoff67
mhoff67
Hy all,
I was testing some engraving "things" and found an "a bit unexpected" behaviour for the Extrude from Offset if the sketch face is in a tangent plane:
Here is a sample test (see pic):    cut (extrude)  a rectangle into a cylinder side face,  if done from a mid plane sketch  it works as expected. (backside cutout)   If done from a tangent plane sketch - the extrude only cuts half of the profile (front )
(This happens also with other shapes in the sketch like TEXT what was my initial try)
Is this a Bug - or did I just misunderstand the feature?
Grüße aus Heidelberg - Michael
BTW: Below also a short screen cast to explain it in more detail.
jeff_strater
Hi @mhoff67,
Yes, that is a bug.  Thank you for the detailed explanation and video.  We will look into this bug.
Jeff
Jeff Strater
Engineering Director
rishabh.bisht
Update: This bug should be fixed with June 2020 release.
Rishabh Bisht
Product Owner
chrisplyler
Holy Crap the speed and efficiency of debugging at Autodesk is mind blowing.
laughingcreek
It's nice that this is being worked on.  It's of limited use with out the chain faces option-
Then there's the wonky behavior when the object surface curves normal to the extrude direction.  you'll note this doesn't happen on the to side of things-
https://knowledge.autodesk.com/community/screencast/eef59ff6-f8a8-489d-bfc4-69d71291eade
Are you folks over there still working on this?
rishabh.bisht
Hi @laughingcreek ,
First and foremost - my apologies for replying so late. This notification somehow got buried in my inbox.
Thanks for the additional info.
To answer your question: let me check this with the development team and I'll get back to you.
Rishabh Bisht
Product Owner
samuel.templeUCPAE
Would there be any way of sharing this file with me so that i can better investigate the issue?
Also, if you would be able to include more information regarding what you are trying to achieve as the screen recording isn't very clear, that would be most appreciated.
I have done a fair amount of testing in this region but would love to better understand if this is a bug or a hopeful improvement.
The more information given, the better equipped we can be in getting back to you with a hopeful remedy
Samuel Temple
Senior Software QA Engineer
(samuel.temple@autodesk.com)
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
