Extract curve from surfaces or solids
Message 1 of 24
Hi there,
I'm seeking for a way, but I can't find one, to extract a curve on the top surface of this sweeped surface (please see the image and you can find the model here: https://a360.co/2RljMa3).
I would use it for a pipe or a loft or just a pattern exactly in the middle of the surface.
Can you help me, please?
Marco
Replies (23)
Message 21 of 24
shootquinn
CATIA literally has a half-dozen ways to do this, one of which is literally a button called "Extract."
http://catiadoc.free.fr/online/cfyug_C2/cfyugextract.htm
https://www.youtube.com/watch?v=VooLF2DsFlo
Message 22 of 24
TrippyLighting
CATIA, Siemens NX and Alias have many curve and surfacing tools that not available in Fusion 360.
They also have eyewatering high price points that are way beyond 99% of the general Fusion 360 user base.
Message 23 of 24
shootquinn
Thus my issue with your first post in this thread, "You cannot simply 'extract' a curve. Depending on what application you are working with sometimes you can create iso curves on a surface..."
Also, this can be done using Fusion's "Include 3D Geometry" tool in sketch --> Project/Include:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-extract-a-c...
From here a user can extrude a ribbon-like surface and offset the surface as you suggested.
This thread has a high google search ranking.
Message 24 of 24
TrippyLighting
"Extracting" a curve from an edge, or form an arbitrary place on an existing NURBS surface results in an approximation of that surface at that "place" within a given tolerance, not a extraction of a original curve that might have been used to create that surface. That was what I was trying to explain in my simplified post to a novice user.
I am sure you understand that "novice" context.
Extracting a curve from an existing trimmed NURBS edge in Fusion 360 very often results in very broken curvature and is also unnecessary to create a ribbon surface, because that can be done directly from that edge.. That, on the other hand usually does NT result in broken curvature.
I have reported this many, many times to the Fusion 360 team.
