Extend Sweep further than the selected path
I've used the sweep function to create a recess in a block I've drawn. I've used the edge of the block as the Path, but because the rear of the block is at an angle, there is still material there which I need to remove.
I've tried the extrude function which removes the extra material, but not at the correct angle. Is there a way of extending the sweep further than I've already done?
Thanks.
DarthBane55
Just so you know, you are posting a design question into the manufacturing forum.  You might have better luck posting your question here: https://forums.autodesk.com/t5/fusion-360-design-validate/bd-p/124
seth.madore
I'll move this thread to the appropriate location
Seth Madore
MRWakefield
This is one way (see attached). I've not exactly extended the sweep but it might be an acceptable solution.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
g-andresen
create a new path
günther
