Extend display region of a construction plane
Message 1 of 11
When one creates an offset plane parallel to a face (which lies arbitrarily within the space), the constructions plane is generally drawn "a bit larger" than the face. Most often this is exactly what one wants, but not always.
Is there a way to enlarge (or shrink) the display size of a construction plane? I want it to "extend over the full model".
Replies (10)
Message 2 of 11
TheCADWhisperer
Can't you simply drag the edges or corners of the workplane?
Message 3 of 11
@TheCADWhispererHow? I don't seem to be able to do that.
Odd. Now it works. Not sure what I do differently though. Thanks.
Message 4 of 11
thanhbinhle0509
I tried but failed
Message 5 of 11
jhackney1972
Be sure your are trying to change the size of a Construction plane.  Then hover your cursor over an edge, to see the yellow line or over a corner to the the highlight dot, left click hold and drag to resize.
John Hackney, Retired
Message 6 of 11
TheCADWhisperer
@thanhbinhle0509
Message 7 of 11
thanhbinhle0509
Oh nvm, I just clicked it and now it worked. Thank you very much for your time
Message 8 of 11
thanhbinhle0509
I just turn off Fusion and then turned it on again and now it worked. Thank you for your time
Message 9 of 11
yashvardhangarg
Community Visitor
Community Visitor
not happening
Message 10 of 11
TheCADWhisperer
@yashvardhangarg wrote:
not happening
@yashvardhangarg
No file Attached to illustrate your issue?
Message 11 of 11
helloXXJ9P
Observer
Observer
In case anyone finds this solution and is stuck (it took me ages to figure out why I wasn't getting the same result as @jhackney1972 in their helpful GIF): you just need to re-enable the 'Construction Geometry' selection filter. Go to Select > Selection Filters and ensure that 'Construction Geometry' is checked. Now you can freely resize the construction planes.
Honestly I didn't know this was possible until I saw @jhackney1972's GIF and then I was so confused why my version of 360 couldn't do it 😄
