Expressions with parameters
Francisco_García
Mentor Mentor
Francisco_García
Hi everyone.
Anyone knows if its possible to make a expression that contain a parameters such as <height>x<width> to describe a part dynamically as Inventor does?
Thank you in advance
Fco. García Bayarri
Delineante industrial | Formador técnico
LinkedIn | YouTube | Twitter | Telegram
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta.
Please give me Kudos and mark this answer as Accept as Solution if it answers your question.
TheCADWhisperer
Show screen capture of the Inventor equation that you are attempting to replicate in Fusion.
Better yet - Attach the *.ipt file here.
jeff_strater
Yes, you can describe a design parametrically in Fusion, as you can in Inventor.  Same basic ideas:  Set up parameters, use them in sketches or features, edit the parameters, and the design will update parametrically.
However, if you are thinking about iParts/iAssemblies or Model States (a configurable component generator), Fusion does not yet have that capability.  It is under development and is planned for later this year.
Jeff Strater
Engineering Director
