Mirror Bug
Mirror Bug
etfrench
Mentor Mentor
Mirror Bug
etfrench
Mirroring features is not using selected plane.
Extrude7 and Extrude8 were created from Sketch4 using Start: Object with the end of Body 5 selected as the object.  Mirroring the two features results in the features being mirrored about each other instead of the selected origin plane.
ETFrench
Warmingup1953
It looks like you are Mirroring Features not Bodies?
etfrench
Yes, as stated in the OP.
ETFrench
Warmingup1953
Sorry I've not used mirror Features in that manner so I wondered if I was misinterpreting the video.
g-andresen
In this case Identical is the better option
günther
laughingcreek
not a bug.  it's doing exactly what your asking it to.  you have start from object selected in your extrude features.  since the mirror is set to adjust, when the features get mirrored the extrudes start from the exact same "start" object.
etfrench
That's bizarre.
ETFrench
