Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Expressions with parameters
2 ANTWORTEN 2
Nachricht 1 von 3
Francisco_García
308 Aufrufe, 2 Antworten
Hi everyone.
Anyone knows if its possible to make a expression that contain a parameters such as <height>x<width> to describe a part dynamically as Inventor does?
Thank you in advance
Fco. García Bayarri
Delineante industrial | Formador técnico
LinkedIn | YouTube | Twitter | Telegram
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta.
Please give me Kudos and mark this answer as Accept as Solution if it answers your question.
2 ANTWORTEN 2
Nachricht 2 von 3
Show screen capture of the Inventor equation that you are attempting to replicate in Fusion.
Better yet - Attach the *.ipt file here.
Nachricht 3 von 3
jeff_strater
als Antwort auf: Francisco_García
Yes, you can describe a design parametrically in Fusion, as you can in Inventor.  Same basic ideas:  Set up parameters, use them in sketches or features, edit the parameters, and the design will update parametrically.
However, if you are thinking about iParts/iAssemblies or Model States (a configurable component generator), Fusion does not yet have that capability.  It is under development and is planned for later this year.
Jeff Strater
Engineering Director
